Hallo nochmal,
Gewichte stammen komplett Fahrbereit mit original Auspuff (IMT)
Hab auch noch diese Daten:
(Quelle NSR-World) gedrosselte Variante
Engine Type: MC16E 90º V-Twin Liquid Cooled 2-Stroke
Crankcase Reed Valve Induction
Bore and Stroke: 54mm x 54.5mm
Capacity: 249cc
Compression Ratio: 7.4:1
Clutch: R models - Wet Multi Plate with Coil Springs
SE/SP models - Dry Multi Plate with Coil Springs
Maximum Power: 40PS @ 9000 rpm
Maximum Torque: 3.3Kg-m @ 8500 rpm
Ignition: CDI PGM-IV
Spark Plug Type: NKG BR9ECM (BR8ECM/BR10ECM)
Denso W27EMR-C (W24EMR-C/W31EMR-C)
Spark Plug Gap: 0.7mm - 0.8mm (0.028" - 0.031")
Idle Speed: 1200rpm 100rpm
Dimensions.
Length: 1970mm
Width: 650mm
Height: 1045mm
Wheelbase 1340mm
Seat Height: 770mm
Ground Clearance: 135mm
Dry Weight R model: 138Kg
SE model: 138Kg
SP model: 137Kg
Capacities.
2-Stroke Oil: 1.2 litre
Transmission Oil: 0.8 litre (rebuild)
0.7 litre (drain/change)
Fuel Tank: 16 litre (primary)
1.2 litre (reserve)
Suspension.
Castor: 23° 15'
Trail: 87mm
Front Tyre & Wheel (R & SE models): 110/70 x 17" Aluminium Enkei
Rear Tyre & Wheel (R & SE models): 150/60 x 17" Aluminium Enkei
Front Tyre & Wheel (SP models): 110/70 x 17" Magnesium Magtek
Rear Tyre & Wheel (SP models): 150/60 x 17" Magnesium Magtek
Tyre Pressure (Front - all models): 2.25kg/cm
Tyre Pressure (Rear - all models): 2.25kg/cm (rider only)
2.50kg/cm (rider & passenger)
Front (R models): Telescopic oil filled damper
with spring preload adjustment only.
Front (SE/SP models): Telescopic oil filled damper with spring preload
and rebound damping adjustment.
Rear (R model): Pro-Arm® with external coil and damper unit with
variable spring preload adjustment.
Rear (SE/SP model): Pro-Arm® with external coil and oil/gas damper unit with variable
spring preload, remote compression, and rebound adjustment.
Brakes.
Man beachte zusätzlich die Gewichtsreduzierung durch Jolly anstelle der superschweren originalen (IMT)...
Dafür ist die Repsol Verkeidung etwas schwerer als original...
Müsste wohl mal wiegen mit allen Flüssigkeiten.
