Übrigens:
Hier mal ne kleine Auflistung aller an den RGV's verbauten SAPC's.
Jap Bike Section
VJ21A models
This model bike came in 3 versions,The FJ,FK and FAK model.They are identical to the uk spec rgv250 L model bike but feature a restricted control box and differant jetted 12c61 indexed 32mm mikini carbs.
VJ22A models -Dry Clutch
The VJ22A bikes came in a number of differant specifications,The models bieng the FL,FNL,FM,FNM,FN,FNN AND FP.
Rgv250 FL Close ratio gearbox,22d20 sapc unit,Mikini 34mm carbs and produce's 45hp.Frame number VJ22A-100066~
Rgv250 FNL Standard gearbox,22d40 sapc unit,Mikini 34mm carbs and produces 45hp.Frame number JJ22A-100717~
Rgv250 FM Close ratio gearbox,22d70 sapc unit,Mikini 34mm carbs,45hp bike.Frame number VJ22A-108084~.
Rgv250 FNM Standard gearbox,22d80 sapc unit,Mikini 34mm carbs,45hp bike.Frame number VJ22A-108094~
Rgv250 FN Close ratio gearbox,22d70 sapc unit,mikini 34mm carbs,45hp.Frame number VJ22A-114645~
Rgv250 FNN Standard gearbox,22d80 sapcunit,Mikini 34mm carbs,45hp.Frame number VJ22A-114725~
Rgv250 FP Close ratio gearbox,23d40 sapc unit,Mikini 34mm carbs,40hp.Frame number VJ22A-120223~
Wet Clutch
The 5 jap wet clutch bikes are the Rgv250 L,M,N,P and R.
Rgv250 L Standard gearbox,22d00 sac unit,Mikini 32mm carbs,45hp.Frame number VJ22A-100056~
Rgv250 M Standard gearbox,22d60 sapc unit,Mikini 30mm carbs,45hp.Frame number VJ22A-108074~
Rgv250 N Standard gearbox,22d60 sapc unit,Mikini 30mm carbs,45hp.Frame number VJ22A-114635~
Rgv250 P Standard gearbox,23d30 sapc unit,Mikini 30mm carbs,45hp.Frame number VJ22A-120119~
Rgv250 R Standard gearbox,23d30 sapc unit,Mikini 30mm carbs,40hp.Frame number ?
Hab ich mal von der Seite vom RGV-Curd gezogen-sehr netter Kerl!
http://abaserv.dyndns.org/rgv/index.php
